- 2,135
- 612
- 113
- Davis County, UT
I make these myself.
$18.00 each + shipping
Located in Kaysville, UT
Newly manufactured from 100% mil-spec parts. These straps are designed to replace the oft missing, damaged, or sun rotten straps on military surplus or civilian aftermarket jerry can or fuel/water can mounting trays. Not intended for life safety devices.
Features:
NOTE: I do not certify nor guarantee assembled breaking strength. Webbing specifications provided for informational use only. Not intended as seat belts or life safety devices.
For best performance, please ensure your strap is installed properly!
Features:
- 53″ long strap.
- 1-1/2″ wide mil-spec, nylon or cotton webbing.
- Available in 13 different webbing colors:
- A-A-55301: Olive Drab (OD7), Dark Green, Coyote, Brown Sand, Sage (Air Force Green), Black
- Nylon
- Type VI, ~0.050″ thick, 1500 lb breaking strength webbing
- MIL-W-17337: Camo Green 483, Tan 499, Foliage, Red, White
- Nylon
- ~0.043″ thick, 1800 lb breaking strength webbing
- MIL-W-43638: Vintage Olive Drab (OD7), Natural color Cotton
- Cotton & Fortisan
- Type II, ~0.095″ thick, 1200 lb breaking strength webbing
- Low stretch
- Mildew resistant & water repellent treated.
- Black coated, solid brass tip, genuine mil-spec, meets MS51926B-5.
- Matte black spring buckle clamp, genuine mil-spec, meets MS51929A-3.
- Heavy, visible outdoor polyester or nylon stitching, UV resistant, anti-wick.
- Also includes your choice of colored elastic to hold down the extra strap “tail”. Add a little accent to your functionality!
- Choose between Black, Gray, Tan 499, Coyote, or Camo Green.
- 55301 Olive Drab (OD7) Nylon
- 43638 Olive Drab (OD7) Cotton (NEW!)
- 55301 Dark Green Nylon
- 17337 Camo Green 483 (NEW!)
