FloridaAKM
- 394
- 83
- Gainesville, Florida
Re: Failure of flex brake lines on a 1987 M35A2C
Well, you hear the horror stories where guys crank up the trucks & head for the open road, only to find that there are no brakes when the pedal hits the floor @ the first stop sign they come to. Today, I took the Deuce to work to drop off a few items that were sold & no problems or leaks. A few miles down road @ the local fueling stop. I noticed that there was a very small puddle under the right front axle of something fresh, not being able to find a problem, it was home bound time. After getting home & looking closer, the right front axle brake line was leaking brake fluid @ the crimp on the flex line. After cleaning the area & putting 10 ounces of Dot 5 brake fluid in the master cylinder (that was a first clue), the brakes were rechecked with a resounding ooooooohhhhh no. The brake line gave way & the pedal went to the floor in the yard, rather than on the road. The Lord works in mysterious ways for me. So I am going to replace both front brake lines before moving the truck back on the road! I am blessed in many ways like this.
The best replacement lines are from where?
