peakbagger
- 344
- 63
- northern nh
One of the fittings on my loader snapped today under load. Its on one of of the boom cylinders that lifts the entire loader up. It was under heavy load, and looks like a fatigue failure. I have kept this system stock and have not removed the "hidden" pressure reducing valve on this system so it was stock pressure (unless the hidden valve is not working). I looked up the part number and sent an inquiry to EI and they responded quickly that its mongrel part. Not mercedes and nothing they have in stock. Its an adaptor 90 degree elbow. The end that screws in the cyclinder side is flat faced straight thread backed up by an o ring and nut. I found that in various fittings manuals but the other side looks just like a JIC straight thread cone fitting but unlike all the fitting manuals the threads are tapered. I went down to a local parts store and they had the right size JIC fitting in a straight adapter. Despite the tapered thread on the originals, the JIC screws right in and appears to seat.
They didnt have the adaptor elbow but will order one in. I am going to give it try but has anyone else run into this odd variation of what looks to be a JIC fitting but with tapered thead?
