toxicroadkill
- 17
- 3
- Danville il
This worked out very well, I took your standard 4 way, welded on a "stop" bar and a old shock metal busing to the 4 way. Got a long bolt and a coupler, makes the perfect place to store your tire iron, to remove, just unscrew it, the pressure against the tire keeps it from turning, with a slightly longer bolt (when I remember to get one), I could eliminate the nut holding the tire hold down in place, and just have the coupler hold it.
The only problem, is I ended up welding in a little more material on the bolt head, it started to make it's way past my stop bar.
