V8srfun
- 536
- 93
- Altoona pa
For those of you that regularly check your hub temps what are you seeing. I am in the process of replacing all of my seals/boots and packing the bearings and want to know what is normal when I am done. I did not monitor temps before service but I do know that one of my hubs was noticeably warmer than the rest on the last drive. When I had them apart the seals were leaking in to the bearings and most of the grease was washed out.
