need hemtt Detroit Diesel 8v92ta mechanic near Sacramento
bigmike
354
Dixon CA.
Update 11/15/2020
After pumping $300 worth of diesel into the tank, I took her out on the freeway for 77 miles. 55mph, 2000 rpm, water temp held steady at 180 degrees, oil pressure held steady at 65 psi. BREAK IN COMPLETE!
What a relief to have the truck back on the road.
next step, fix the leaks on the crane.
