Official NC Denton Rally 2021 Buy/Sell
Ferroequinologist
Resident railroad expert
723
Liberty Hill, SC
Great. Do you have a pic of the rims? Price? Do you happen to have the front bumper shackles and mounts? I'll see what else is need and let you know.
I'm in VA this week, but will be home next week and can get pics.
I think I do have a set of shackles and mounts but will have to dig around some.
Floridianson
2,437
Interlachen Fl.
If you do not find the shackles I seem to have some 3/4 pin shackles that look almost like the ones on my 37. I packed them with the other bigger shackles for the trip up there. Maybe someone can look sea because I do not remember where they came from or really care.
19,034
I have some sets of screw jack legs for the expandable van shop trailer corners or the expandable shop truck.
Now all I need is a M915a2 with a Detroit power plant and an expandable van shop trailer out of Florida
- and if I had one -
The I might need a few sets of screw jack legs.
:cool:
Phoenix77
543
Greenville, NC
Off the top of my head I have 13 LMTV shackles, over a dozen different sized Hardigg cases that are manageable size (for reference, a bit smaller than M1078 driver's / co-driver metal boxes) if you want water tight storage in your MV while still freeing up some real estate.
I don't know if anyone is looking for wires with correct military connectors (round multi pin), but I have an obscene amount I carefully removed from my S-280 Electronics Shelter when stripping it.
I have a HEAVY (~200lbs) lockable aluminum water tight 7' long storage box that if you stood it up, honestly could pass as a gun safe, that would make a great truck box for any 2.5t+ vehicle of sufficient width. I have two (2) and plan on using one (1) for said purpose in my M1078.
I also have a running M1081 for sale, but I'm about 100% certain that isn't going to be there... It's a long walk back to Greenville
SCM35A2
2,714
Florence, SC
I'm interested in some of the LMTV shackles, very curious about that big a$$ box too lol. Scared to ask what you want for it, but its very cool.
Phoenix77
543
Greenville, NC
Unfortunately it is doubtful I will make it to Denton, but the "big a$$" boxes are $300 ea.
I have 50 cal, 40mm, and 60mm ammo cans for $10 ea as well.
LMTV shackles are $50 ea., without assuming shipping cost. I can probably stuff a couple in a prepaid USPS box for a flat rate shipping cost, or pick up is great.
wheelspinner
1,508
North Carolina - FINALLY !
Why can’t you make it? Dang man
Ferroequinologist
723
Liberty Hill, SC
Has exhausted my time & resources. I'm now woefully behind on the HoneyDo list and have dug a substantial financial hole from which I need to emerge.
I always use the "well so and so wants to buy this or that, but can't make it here. If I go to the rally/show, I can take them X items, and make some money. Plus then I can take more stuff to sell, and clean up more junk you complain about and make even more money!"
Then just barely audible I say in my best end of a commercial speed voice- *all money made stays in my pocket and items sold may or may not be bought back at a later date if I got rid of them too soon. Consult your doctor if it appears I returned with more/bigger/heavier items then I left with, this maybe a sign of a serious mental affliction known as 'nagging wife syndrome'. Additional terms and conditions apply if I need to think them up to placate you.*
Ferroequinologist
723
Liberty Hill, SC
Here is a couple pics of one of the rims.
I have the lock rings matched to the rims.
Looks like I have two good ones, and two with rust pitting on the inside face. Perfectly serviceable however. $50 each for the good ones $30 each for the pitted ones.
I only found one spare set of shackles, and no mounts. I thought I had more and the bumper mounts. I probably do they just got lost in the move. I'd take $40 for the pair.
Floridianson
2,437
Interlachen Fl.
Do those air tanks have two divided chambers? Mullaney is looking for some air tanks for his truck. The ones I am bringing are divided and need the center divider drill out to make it into one chamber. If those are not divided they might might work better in his case. Just a thought.
Ferroequinologist
723
Liberty Hill, SC
They are single chamber tanks, but off bigger trucks. I assume he needs them for a deuce?
I plan to bring a few.
19,034
I am looking for a 5-Ton M936 air tank.
The tank I need is under the driver's step. (wet tank I believe).
I rigged it with an aluminum tank that really doesn't fit the space.
Would prefer the factory more for fit than anything...
The two chamber / split tanks that Floridianson has can be modified and
even if not, a few extras in my stash will be good to have on hand.
Don't think there is any such thing as too many spare parts :cool:
Ferroequinologist
723
Liberty Hill, SC
Why do you think I have a stack of tanks? 😂
I'll check and make sure I have single chamber tanks and bring a few with me.
swiss
692
Oakwood, Ga
Subscribed
Looking for 900 series steering wheel
Stuff for sale:
1.) Medium towbars, 1" and or 3/4" feet or both (real pins not bolts stuck in)
2.) 20' Jumper Cable (complete and rebuilt)
3.) Tow light kit with cable
4.) 25k GAR winch (no cable)
5.) tons of other stuff not cataloged at this time and spread out everywhere
