Keith_J
- 1,313
- 113
- Schertz TX
DB 2829-4521 is a CUCV IP. Specifically, a 1.2 centi Stoke JP8 rated pump for 1986 calibration. It is a 12 volt unit.
It is a replacement unit as 1986 came with a 4520, the only difference being the low viscosity wear parts.
Since the vehicle is a 1984, the original pump used the flex ring, all military replacements were 4521 calibration as this model doesn't use the flex ring.
