1952 M35 Gasser ignition?
52REOm35
Olympia
I have a 1952 M35 gasser that I’ve been trying to get some spark out of with no luck. I can’t seem to find a tm that covers these old gassers either. Can anyone tel me if the power going to the coil is 12v or 24v? I have replaced the points, condensers, rotor, cap, coil, resistor, plug wires and plugs. I’m getting 24v to the resistor, but on the other end of it is 12v. Am I missing something?
gringeltaube
Staff Member
2,254
Montevideo/Uruguay
.......I can’t seem to find a tm that covers these old gassers either.
That would be TM 9-2320-209-20 (Feb 1965), Section VI, starting on page 107: Troubleshooting the electrical system.
(This is a 64MB manual and I don't think we have it uploaded yet, in our library. I will try later on...)
Following 6 pages cover the ignition system.... (extracted from above book)
Hope this helps solving your issue.
NDT
5,828
Camp Wood/LC, TX
Yes the resistor reduces 24 to 12 volts.
With the ignitor cover off, stick a solid wire core ignition wire into the coil tower and crank, this will remove the cap and wires from the equation for diagnostics.
