NJ 1966 M35A2 w/ Winch and Canopy Bed
Skipp0211
North New Jersey
1966 Jeep/Kaiser M35 A2 2.5Ton
Front Mounted T-Case driven 10k winch - Needs to be taken apart and freed up
Full bed with Canopy - could use a new tarp
All tires hold air and aren't that bad, i was going to super single it
No real Rust or rot, just the usual dry rot from sitting and being so old.
2 New Group 31's - 24v system.
The truck will start with half a crank every time. Full Mechanical Hercules Multifuel with a turbo.
Here's the bad, truck has no brakes. I haven't dug in deep enough to see whats going on. Probably needs a master, wheel seals, maybe an airpac. I planned on just going through each system and fully replacing/rebuilding.
It runs awesome, drives, shifts, etc. I've driven it on my property at work, just doesn't stop unless you use the parking brake.
Title is clean and clear
I'm asking $6000 obo. I'm open to trades depending on what it is.
I can send detailed pictures etc through text if youd like.
20220318_155653.jpg20220318_155718.jpg20220318_155721.jpg20220318_155727.jpg20220318_155736.jpg20220318_155816.jpg20220318_155824.jpg20220318_155833.jpg20220318_155837.jpg20220318_155842.jpg
