WA 1984 American General M923A
5TonKayak
Kitsap/WA
1984 American General M923A "0" (dual rear tires) with Cummins NHC 250 / Allison 5-speed. ABS retrofit installed. Only 6,205 miles, 1,128 hours!
Dropside cargo bed hinges and latches all work, have dropped all sides at different times). Troop seats have wooden backs, fiberglas seats.
Bought it for a short job as a portable stage in 2013 and the most miles I've put on it since are the occasional trip to the post office and a yearly car show. Selling because I want it to get more use and love than I can give it.
I've replaced the alternator with a Spider Marine unit, and replaced four Hawkers with two big 12v AGMs designed for solar installations. Battery compartment has AC inlet installed for a NoCo tender (not included).
Replaced a rear axle seal, and will include a couple of spare seals.
Added enough bows to fully support the cargo cover. Cover is in very good condition, no leaks or broken rubber straps, except one cut in back left panel that came that way from depot (see picture).
Engine starts right up from cold with a pushbutton of ether (new canister 2019) runs beautifully, drives well at highways speeds (55-60 mph). Idles steady at 600 RPM, no fluid leaks!
Includes two spare tires, extra bows, and short aluminum ladder.
Known maintenance issues:
Soft top in great condition, no leaks. I got it with FME tape on front edge, replaced it once because old tape was starting to lift.
Some rust starting to show through, and needs to be repainted at some point in near future.
Turn signal needs to be looked at, I just haven't had time. It takes some time to "warm up" like a cold solder joint or bad contact. Starts working the first time 3-4 minutes after turning it, then works for the rest of the drive.
$15,000.00 cash. I have clean title.
5TonKayak
Kitsap/WA
Would prefer to sell to a fellow member - I'm willing to meet in WA state (okay, maybe not Spokane, sorry @wsucougarx ) for serious buyers. Price is also negotiable, all reasonable offers welcome!
Brad 5TonKayak
5TonKayak
Kitsap/WA
Bump. If you think my pricing is a little too proud, feel free to make an offer, or even a suggestion based on what you all know the market is like.
Thanks!
Brad / 5TonKayak
