1998 MTV M1083 Fan Clutch Engages and Shuts Down Electronics
joelnelson1207
Reno, NV
Hi Guys,
My name is Joel. I have a M1083 with CAT 3116. Was just driving down the highway and said to myself, "this truck runs better and better every time I drive it". I should have kept my mouth shut. It left me on the side of the highway 30 seconds later!
I have the following problem with the following symptoms:
(a) - When coolant temp gets to 200F fan clutch solenoid kicks on and engages fan clutch as intended and as it has always functioned correctly.
(b) - When solenoid clicks (psssst sound under passenger relay panel), the fan engages as intended, but...
I get an IMMEDIATE TOTAL ELECTRIC SHUT DOWN.
e.g. gauges in cab shut down, fuel shut off solenoid closes and engine stops and I roll to a stop.
If I cycle the master power switch off, then back on, I get power. Fuel shutoff solenoid opens. I start truck. And all runs fine. UNTIL temp gets back to 200F again, fan switches on, then shut down cycle repeats.
NOTE:
(a) - problem / symptom is intermitted. e.g. it happens about 50/50 when temp reaches 200F and fan clutch engages.
(b) - Last week like an idiot I ran the batteries down, tried to crank starter on low batteries before I charged them. I mention this because a year ago I did the same thing and damaged the K1 relay and truck wouldn't start (even with charged batteries). I replaced K1 relay w/ new relay and all works fine.
Questions:
1 - Could I have damaged a different relay this last time I let batteries die? i.e. fan clutch relay and/or temperature sensor?
2 - Where is the fan clutch relay located / what # is it in relay panel? I have looked at diagram and don't see anything that says "fan clutch"?
3 - Is there some short to ground in the circuit?
Anyone have this problem and can suggest a troubleshooting path.
Thank you all.
Sincerely,
Joel
PS - you can call me too if that would help (775) 223 6633
HDN
4,730
Finger Lakes Region, NY
I suggest posting your question in the FMTV section since this section is mostly for the trucks that came before the FMTV that don't have modern fuse boxes in them. Aside from that I unfortunately don't have an answer for you :( Good luck!
simp5782
Feo, Fuerte y Formal
9,256
Mason, TN
Hi Guys,
NOTE:
Questions:
Thank you all.
Sincerely,
Joel
Short to ground on the circuit completion. Temp control unit is opening letting power across to engage the fan solenoid and it scrambling the ecm
  • Like
Reactions: HDN
