20k front hydraulic winch
HN6
401
alaska
I tried pulling a 40' connex with the winch yesterday. Prior to hooking the big winch up I used my 8k warn electric. The 8k warn did a better job.
I remember someone else complaining about no power with the front winch on these big trucks. Thinking about redoing the valves as well. Not very user friendly but definitely soldier safe.
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
It's better to use the winch to lift the one end and let the truck drag it.
It's only a 20,000lb winch. Not 20ton on a 5 ton.
Winch should have pulled it or drug your truck back in.
The rear winch on a wrecker Is 45k. It won't pull the wrecker out unless you can get up higher to release the suction and not bulldoze
HN6
401
alaska
Ooops yes 20k . We also had the connex on telephone poles so the it would roll no luck. I put the truck in reverse and just pulled it.
HN6
401
alaska
What gear did you have the truck in when running the winch?
Neutral. I did rev the rpms up but I did not try it in gear. I thought it would be simple like my hydraulic winch system on my boat. engage the hydros and system ready. need a little more power add a few rpms.
HN6
401
alaska
Which TM would I reference for the winch? I looked a little yesterday but no success.
