24 bolt wheels Help
Jakelc15
36
Hanover Pa
I have a set of 24 bolt wheels and need to replace the o-rings and a few studs.
I can find the parts for the old 8 bolt and 12 bolt wheels but not the 24.
Maybe they're the same but I didn't think so.
So I'm wondering if anyone has had any experience with these or has the updated TM or parts manual for them. I have searched and can't find the right one.
Any info would be appreciated.
Jakelc15
36
Hanover Pa
I'm also looking for replacement studs and another 24 bolt rim for a spare, the equidistant kind.
Jwaller, let me know what you want for some o-rings.
Jakelc15
36
Hanover Pa
Ran across some old notes I thought I'd post. Seeing more of these rims around.
24 bolt wheel, equidistant studs
Nsn 2530-01-558-3027 wheel, inner
Red o-ring pn: 12460338 nsn: 5331-01-417-1043
Inner rim bolt: 12342758 1/2"-20 x2.12
I have a bunch of the nuts left over that fit these if anyone needs some.
Other part #'s found in the TM9-2320-280-24p
These are found on the m1151a1 m1114 and other up armored hmmwv, currently used.
Hayes Lemmerz International wheel
kfrosty
Belmont, NC
Piggybacking on this thread. I've got bunch of 24 bolt rims I need to put together. Looking for a place to buy bulk.
I happened across this thread on Pirate talking about 8 & 12 bolt rims.
http://www.pirate4x4.com/forum/general-4x4-discussion/414516-h1-hummer-wheel-o-ring-specs-3.html
They mention marcorubber.com and using buna -457 & -458 but seems those aren't the exact size for the latter 12 bolt and 24 bolt rims.
http://www.marcorubber.com/sizingchart-oring-usa.htm
Does anybody know the inner and outer diameter's of the o-rings for the 24bolt wheels?
Link for McMaster-Carr (Still haven't figured out the sizes)
http://www.mcmaster.com/#catalog/122/3536/=14cofks
If anybody has one of the red ones can they measure and I'll order a couple of sizes and post if any work.
DatGuyC
17
Essex, Maryland
46.5" long for a 16.5 rim?
I updated my original post. The 46.5 is from marking the ring with a sharpie and measuring how long it was going around, it gives about a 15" circumference. From looking on McMaster it looks like they might be dash number 384 high temp silicone orings.
Action
1,550
East Tennessee
A 16.5" circle has a cicumference of about 51.8". The o-ring is smaller than the rim, so 46.5" seems about right. He is saying that if the o-ring is cut and put in a line, it will 46.5" long.
ryanruck
Cincinnati, OH
After not getting any response in that 24 bolt torque spec thread, I got in touch with another SS member I know who has access to the up-to-date TM 9-2320-387-24-1 and he was kind enough to send me a PDF of the scanned section in question. Should have the info you need.
tobyS
815
IN
Why would you use high temp silicone, rather than the same as most other military wheel o-rings, Buna N and 70 Durometer?
DatGuyC
17
Essex, Maryland
No idea if the military ones are silicone or not, I just noticed McMaster said their high-temp silicone ones are red and the military ones are also red.
tobyS
815
IN
I haven't taken a HMMWV wheel apart, only the 5 ton combat, MRAP and the A3 deuce. Just wondering why using a high temp.
S70385 is a 16" id, cost 9.84
B70385 is 16" id and cost 3.42 Operating temp -40f to 250f
