3/4 ton springs and ord flip
Bigbondo007
Arabi, ga
Finally got the 4" Superlift on the front and the 4" ord flip on the back. Now should I fit hmmvw 37s or go with 35s? BTW the civvy k5 i have has 36s and is 1/2" higher in the front and will scrub. I absolutely refuse to trim sheet metal on this truck.
Sent from my SM-N950U using Tapatalk
Bigbondo007
Arabi, ga
How much did you trim? I'll probably have to go more without the counterweight you have. Although I found a set of 34.5's and mt classic 2 wheels for cheap last night
Mad Texan
1,150
Chester County, PA
The directions for the flares say 1" on the front and the rear. I was closer to 1.5"...
My truck actually is a little higher in the rear than it looks in that picture... but I'm still building out the back.
Chaski
55
Burney/CA
Mr Sawzall has to come out to fit 37's with a 4" lift… Unless you never deviate from a straight line, or articulate your rig and have springs out of a Peterbilt.
IMHO -If you choose wheels carefully (stick with around 4.5" backspacing) you can get away with 34-35's but it will be close.
