MA (3) MEP-802A for Sale
Light in the Dark
2,778
MA
I have three units available, all need work. Life changes have necessitated that I move out my sitting inventory as expeditiously as possible. All three are not turn key ready and working... but are offered with full disclosure of what I know about them. Happy to arrange freight on any of the machines anywhere by common carrier. More photos of any machine available upon request.
First Tan unit on left (1997) - $1,400
Apparent Tier 2 unit, with Tier plate missing
Will not build full RPM (13-1400 by my ear) but making power (hertz and voltage gauges aren't registering as both figures are below the range... but I did measure 108V at the outlet with my handheld meter while running). May be running on a single cylinder. I've pulled the metering pumps to check for issues, but no change in state.
Middle tan unit (2007) - $1500
This unit was fully load bank tested and totally gone through before being diagnosed with an engine issue. Large amount of blowbly in the case, and small iron filings found at the drain plug. I believe one of the cylinders ate its rings, and gouged the wall of the cylinder. May be able to be saved with a hone or overbore, or could easily replaced with a new DN2M engine from @wheelspinner . Best condition of the three, knowing the issue.
Tri Color Camo (1994) - $1200
Completely untested. The fuel filter bowl was stolen out of this machine for use in another (easy to replace, I just didn't have any in stock). The belt is loose and the crank pulley is also loose. Have not been able to test for free spin because of this (and I am not disassembling the rear to properly torque the bolt back to test in my fire sale). There may be other small items that have walked or are missing, I can give a complete rundown if interested in this machine. Does show some sign of nesting.
No taxes, no premiums, no BS. I've taken the hit on all that sitting on them. In a spot where I have to move them out, no two ways about it. Hopefully one catches your eye. Thanks
