6.2 to bbc sm 465?
pevrs114
32
Monroe, NC
You may want to search in the CUCV forum, you'll find some fairly detailed posts regarding putting an SM465 behind a 6.2L
Biggest hurdle, if you have all your other parts sourced, will be your flywheel. There are extensive parts lists and detailed swap information in the other forum so give it a check and see! good luck.
