68 m35a2 brake light issue
ToddJK
4,464
Sparta, MI
I'd start with this TM9-2320-209-20-2-1. Check it out and see if you find anything and then if not, come back and let us know and we'll go from there.
If you do find the issue and correct it, give us an update as well, this way others who have the same issue know right where to start and they have the TM for reference.
HDN
4,727
Finger Lakes Region, NY
Are you sure the parking light switch isn't on? I discovered what it did the other day 💩
(I don't park my truck anywhere much and leave it running, or any of my daily drivers for that matter.)
On second thought, that might not control the brake light bulbs.
Jgrah777
Buckley wa
Did you do anything before the lights got stuck? If so go back there.
Did they stay on when the switch was disconnected?
Are you certain it's the brake not parking lights?
Does the wiring look modified before you got the truck?
It's definitely the the brake lights. Because when I first turn everything on the running lights are on. And then when I step on the brakes they get brighter but they don't go back. I replaced the pressure switch but I'm thinking it has something to do with the master cylinder not releasing all the pressure.
ToddJK
4,464
Sparta, MI
When this happens, any of your brakes seem stuck or will the truck still move freely? Does the brake pedal feel harder or depress less after it's been pressed and the lights are stuck on? Is there slop in the pedal afterwards?
WillWagner
2,389
Monrovia, Ca.
Could have been converted, I did mine. The reason for asking is to determine which side to look at. One can be a diaphragm/check valve in one spot, the other can be an issue in two different places.
Al Capone
37
Pearl river la
Hi I have a very old m51a1 dump . Brake light switch is on the hydraulic side and not working . I just went thru brakes . New master , all new brake lines and new wheel cylinders . No brake lights . What’s your suggestion? Convert to air side ? I see big mike had conversion kit .
