804B slow fuel drain
primuss
11
Kansas
Started working on an MEP-804B with 39 hours on a M200 trailer recently. Just starting this new addiction with gen sets and been reading a lot.
Doing pre start maintenance and the gauge shows 3/4 tank fuel. Which was odd since the oil had been drained. Anyhoo, put a fitting and hose into my container, scrapped the paint off the cap on the drain that had never been off, opened the valve, and .....just a weak little stream. Barely more than a fast drip. I made sure the valve up on the side was wide open, even blew into the end of the hose thinking it would clear up some crud blocking the drain. Still just a weak stream. I've got about 9 gallons out by letting it run while I putter around, but I'm thinking I need to figure out why it's draining so slow. Any suggestions?
Guyfang
23,396
Burgkunstadt, Germany
Have you shined a light into the tank? Sometimes things you don't even want to know about grow in a diesel tank, when the fuel gets old.
primuss
11
Kansas
I have not. I will do so when I get home in about an hour and report back. The fuel that is coming out looks and smells fine at least. Big forest delivered some filters today so maybe I can spin off the one on the side and peek in there too. (This is so much fun, why did I wait to start?)
primuss
11
Kansas
Nothing to report. I looked down in the fuel tank through the fill neck (after removing the strainer) and all I saw was nice looking fuel. I exercised both valves on the line and blew into it again. I heard it coming through fine. I'm just going to but new filters in and see what happens.
