8420d24 south wind heater 20k btu installation feed pressure?
Crazyguyla
32
Hawthorne, FL
It's possible, but with the heater under constant fuel pressure; your heater could flood with fuel. 1991, Doha, Kuwait; the fire that wiped out 11 ACR's motorpool was started by a heater flooded and started the fire. It didn't help the heater was in an ammo carrier, stuffed back behind the ammo racks.
For safety sake, use a separate fuel pump that can be off when the heater isn't being used.
A Blind Man
Canton, OH
Fair enough, as far as pressure any low pressure fuel pump good enough?
