captain
- 0
- 6
- South Eastern PA
Its time to change my trans oil and filters in my 925a2. It has been running fine for the past 10 years. It came with motor oil. I'm not sure if its 10w or 15w-40 but I think I'm going to put 10w in it.
I am not a big fan of the oil to oil cooler for the trans. I dont think they cool very well and have the potential as they age to leak and ruin the transmission. Has anyone put an oil to air cooler in? What did you use? Did you bypass the OTO cooler?
I have not seen many threads on specifically what brands of 10w oil to use. They are hard to find locally. My options right now seem to be Napa TO-4 SAE 10W Transmission drive train and hydraulic oil. Shell Rotella HD tractor transmission and hydraulic oil. That one might be a 10w-30 though. I have seen no mention of either being used on here. Or I can mail order some Mobiltrans HD 10w but that is really more then I want to spend. Only 1 person I can find has used the Mobiltrans. I normally shy away from Valvoline because every time I look into using them the manufacturers tell me its less then preferred. An example is my Eaton trutracs. What brand of 10w oils are we using and how do we like them so far?
My understanding to change the trans fluid is as follows. I should drain it then refill it. Then drive it until it is hot and drain it and fill it one last time. Do I change the filters on the first or 2nd drains?
Please correct me if I am wrong here. I can use the same 10w oil in the trans as the power steering and the hydraulic tank for my winch.
Sorry for all the questions. I have read posts on this stuff for a year or more and I cant put the work off any longer.
