A2 turbo specs
skav
Castaic/CA
My turbo may be going out and I'd like to get info for the OEM replacement. Does anybody have the info from the data plate? Mine is painted.
Thanks!!!
74M35A2
312
Livonia, MI
They used Holset HX40 and H1E interchangeably. Here is the tag on mine I just shot for you, open fully and zoom if you need. If you plan on wicking up the fuel, and you are buying a turbo anyway, maybe think about an HX50? Ours do well also though, up to approx the 300hp level or so. They do sell bearing and seal kits if your impellers have not rubbed the housings.
skav
Castaic/CA
Perfect. That's what I was looking for.
Good idea about the HX50 too.
Any idea what turbine and compressor housings you'd need with the HX50?
74M35A2
312
Livonia, MI
I'm not an expert, but I don't think an HX50 is configurable. Meaning, it is the compressor and turbine sizes that make it an HX40, HX50, HX52, HX55, etc.... The HX50 is used on slightly larger Cummins engines such as an older L10 model. You could get one cheap from a used truck parts yard. Put a kit in it and have a good genuine turbo, not a Chinese knock off. Cummins also used them on the 8.3L in applications where the engine made 300hp or more, most commonly marine. Could start here to learn more: http://www.myholsetturbo.com/modelinfo.html
People that really juggle turbos say that Holset are on the lagging end of technology, and that almost any newer Borg Warner S series or such will do circles around them. I don't know, maybe? Another thing to look into depending upon how serious you wanted to take the replacement/upgrade.
