Accessory Feed Point
Russ Knight
1,054
Perry, FL
Where is the best place to tap into for a high amp 24v feed for multiple LED light bars, cab light, 24 to 12v converter, and large LED backup lights which will be controlled via dash mounted toggle?
Thank you,
Russ
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Thank you,
Russ
24v is half the amps of 12v. You can just run a wire off the back battery block in your battery box. Just add an inline fuse.
Rops cab trucks have different dash wireharness layouts than regular m939 trucks so you dont have the same loose wires we do.
Sent from my SM-G935P using Tapatalk
Tinstar
1,756
Edmond, Oklahoma
A long drive on a hot day to get the flat spots out will help a lot.
At least there’s quite a few new surplus tires around.
Russ Knight
1,054
Perry, FL
I've been to the woods and rode for miles in sand mode. Still have one tire that won't behave itself. Pretty sure it's the right rear. Made a couple of runs with my mounted gopro back there on each side and it appears to be the one.
MarcusOReallyus
815
Virginia
As mentioned, go to the battery box. Get cables made at BestBoatWire.com. Good stuff. Marine grade, cut to length, with your choice of connectors. I like to add the clear heat shrink to each end.
Fuses & fuse blocks, it's hard to beat the quality of Blue Sea Systems.
Consider going with a Mega fuse for that kind of load.
Tinstar
1,756
Edmond, Oklahoma
That won’t do it.
Needs to be at Hwy pressure and on pavement at speed.
This heats up the tires and will help even them out.
Works wonders
