Air Compressor Question
M35A2-AZ
381
Tonopah, AZ
What is the pressure that the air compressor should turn back on?
The problem I am having is that the Air Dryer is popping off a lot.
The truck builds pressure ok and the Air Dryer popes off the at round 120psi and it looks
like the compressor comes back on at about 110psi and builds back to 120psi and the dryer popes off again. All this takes about a one min.
1,168
Have you serviced your air dryer recently?
Suprman
646
Stratford/Connecticut
When you reach governed max pressure, the governor tells the compressor to stop making pressure and it also tells the air dryer to vent its expello valve. Thats how the air dryer purges moisture it has removed from the air. I prefer my governor to be set around 135.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
I would think lowering the turn on pressure would be fine, maybe 90psi? I'm sure there is a "spec" for the on and off pressures somewhere.
Suprman
646
I dont think the expello valve is adjustable. If you look on the air dryer there are 3 lines going to it. Air in, air out and the air line from the governor. I believe its branched off the unloader air line.
M35A2-AZ
381
Tonopah, AZ
Grimpyrobb, I do not know how to change the turn on PSI only the turn off psi on the reg.
Suprman, I saw the little line that runs back to the reg. (governor).
MtnSnow
14
NSL, UT
When I first got my truck the air gov was set to about 110-115 psi and had a bunch of issues like you describe. after servicing my dryer and the rest of the system I adjusted my air gov to 130-135 psi and my system is much happier now as well as the CTIS system seems to work better too.
PETE BALLARD
Plainfield,Il
You should just buy a new air governor, they are so cheap it does not make any sense to fool with them - in the past i have tried to re-adjust them only to replace in a month or so when they revert back to unacceptable antics. Short story- service your air system annaully which should include the air dryer components and governor and you will never be on the side of the road doing the old bypass thing. Also keep in mind that some of the newer emergency and service valves have higher crack pressures so going up to 130-140 is not a bad move. Last air gov that i bought was brand new and cost $21.05
I forgot to mention, check the line going from the compressor to the dryer for leaks, a leaking line will also result in the same situation happening - continous perging.
M35A2-AZ
381
Tonopah, AZ
