air shift or not- is there a year cut off?
Monster Man
how do you know if the truck has airshift? The one I'm picking up Friday is a '67, I've seen earlier ones with airshift and later without, so what was the rule on those?
1,807
No steadfast rule. Spring seats and air shifts started being standard around 1970 but tons of earlier trucks had em. I once had a gas truck with the spring seats and air shift transer case.
Longhunter7
Northern Illinois
MM!
The best way to tell if a Deuce is "AIR SHIFT" is to look at the bottom of the dash, right under the steering wheel! <img src="emoticons/icon_smile_help.gif" alt="Help">
There will be a bracket with a lever and an instument light! <img src="emoticons/icon_smile_idea.gif" alt="Idea">
When you engage the front axle, the light will tell you that you have 6 wheel drive! <img src="emoticons/icon_smile_thumzup.gif" alt="Thumb Up">
Monster Man
cool, thanks. Sorry for the quality, but looking at this dash can you tell if it is airshift?
<img src="http://www.buschandbusch.com/zdash.jpg" border="0">
1,807
Not that one man. No lever on a little pod hanging from the bottom of the dash. Don't fret it though. Properly adjusted the sprags don't get you out of trouble, they keep you out of trouble.
Desert Rat
MM;
On a further note, improperly adjusted sprags have a nasty tendancy to engage the transfer case at high speeds and kill 5th gear. I'm not interested in taking chances so I dropped the front drive shaft from my truck and I'll wait to get the air shift that I want. She was originally equipped with air shift but someone else (Uncle Sam) had other ideas.
militaryguy
albany OR
what I see! there is no air shift! It's on all the time when it is in first gear. Also reverse gear and limited gears.<img src="emoticons/icon_smile_big.gif" alt="Big Smile">
