Almost done
Hunter2506
Colorado
Well, I've had it a little over 3 weeks, and I've just about wrapped up the details. Still need to replace the driver window frame, replace all the wood for the troop seats and get the horn button to stay put. I got the sprags replaced, all fluids and filters changed, all lights working, etc. And after 32 cans of Krylon OD and 1 can of flat white, it sure is lookin' purty (IMO). Just thought I'd share.
And one at work, just for fun
1,128
Wow, that looks good! Great shots!
WillWagner
2,610
Monrovia, Ca.
You have a very nice looking truck. Did you do the sprag without taking the t-case out?
Hunter2506
Colorado
Do you have any "before" pics?
Yes. It's a tight squeeze, but with the speedo drive housing removed and the fork lever loose, I was able pry the housing out about 1-1/2" and then rotate it 180 degrees, finally squashing my abdomen with it once it came off.;) I expected some weight, but that sucker surprised me! Weighs nearly as much as a complete T-case assembly for a Jeep or S-10 blazer, etc.
