Any ideas on a CTIS wheel balancer...
islandguydon
782
Michigan
I thought some where there was a thread on a A3 wheel balancer. Since the A3 has CTIS the wheel is not balanced. 1/3rd of the wheel has the heavy metal cover plate. This just seems wrong. Is there such an animal made to balance out the blank spot...........?
Rustygears
Ramona, CA
There is a counterbalance weight mounted opposite on one of the rim studs. It does balance out the cover and the plumbing and the wheel valve. While not perfect, it certainly improves the balance over what is being suggested.
There have been many prior threads on balancing A3 wheels using external weights, extra lug nuts on the studs for the rim halves and even internal shot. Search and ye shall find.
319
Lieutenant
49
Michigan
The wheel half studs, not lugs, are long enough you can easliy add weight all the way around the outer perimeter. With the CTIS components removed, you may not need to balance it at all.
islandguydon
782
Michigan
I did 2-3 searches, came up dry. I'm taking delivery on an A3 and was making a punch list. Good looking out..!
islandguydon
782
Michigan
The wheel half studs, not lugs, are long enough you can easily add weight all the way around the outer perimeter. With the CTIS components removed, you may not need to balance it at all.
Good point. It does make the truck look better. Just found out on the back side it's taken care of. I guess I will fix the plumbing or remove it. I was thinking of wheel lock out's. Jtonka has the quality ones. I saw one the other day it was chrome and had red 4X4 printed on it. Just looked wrong.
trukhead
dane/wi
I was thinking of getting the end of an rear axle and welding it to a stand. I would take apart the bearing and super clean it and pack it with petroleum jelly for minimal rolling resistance.
Just mount a wheel and let it roll to the heavy spot an add weight until it comes to a stop at random positions.
:grd:
gringeltaube
Staff Member
2,259
Montevideo/Uruguay
I was thinking .........
think again... because it won't work well using the stock roller bearings, no matter how "lightly" you lube them... (been there, done that...!)
You need a hub and adapt relative small ball-bearings, and mount it on a custom spindle - not that difficult.
For reference, see my M35 "drum/wheel/tire-balancing device" here.
BTW, I have been using that same method for all my vehicles, since my first set of Cepek's 40" Mud Country II, on my '78 CJ7 (wow, that was exactly 30 years ago...!)
G.
