Ball Joint Taper
WagonDriver
California
Hello, found one of my lower ball joints failing, and after pulling it out it looks like the taper in the portal has had a hard life as well.
Has anyone had any luck using a taper reamer to clean up the bore? If so do you happen to know the taper angle?
Thanks!
Mogman
9,223
Papalote, TX
Thanks!
Welcome to the SS forums!
Mogman
9,223
Papalote, TX
The trigonometric solution is to measure the two holes. Subtract the small hole from the large hole divide that by 2. Then take the arc tan of that answer divided by the cross-sectional area of the hole in the upright. :LOL:
Mogman
9,223
Papalote, TX
Hopefully someone actually knows but GM uses 10deg on their trucks and just about everything on a HMMWV follows GM
