m35a2cowner
- 2
- 16
- Columbus, Ohio
One of the front hubs on my deuce is a bit loose. I tried tightening the wheel bearing but no change so I am guessing that the ball joint (for lack of a better term) is worn. Is it a major job to do? Any special tools needed? Also, last year I replaced one of the boots and it seems to have developed a hole again. I was pretty careful when putting it on and wired up the zipper and sealed the zipper as the instructions said to do. Any ideas? Also, has anyone adjusted the shoes using the 1 1/4 nuts which adjust the brake shoe seats? Thanks for any help you can give.
