Best answer ASAP (M1101 Trailer Tire Pressure)
RjSteed
Wesley Chapel, Fl
I know it has the suggested tire pressure on the tire.
Friend of mine is on his way home with an M1101 Trailer he Just purchased from Ft Gordon.
Says the trailer is bouncing around (Not sure how much) but is asking what best pressure for an empty trailer would be for empty travel on road an hwy?
He does have two spares he brought with him just in case and is putting those in the trailer for some weight.
I'm thinking part of his problem may be that he has forward tilt on the trailer cause he is pulling with a Nissan Frontier I think.
Less tire pressure would cause more bounce would it not?
porkysplace
1,487
mid- michigan
Speed may also be a factor , slowing down may reduce the bouncing .
73m819
319
gainesville, ga.
Less tire pressure would cause LESS bounce because you would have a softer tire (flat tires DO NOT bounce)
4,744
17 PSI ?! Wholly Crap...
Whys the tire say 50? Should he ever use the 50?
Might wanna read the tire again. Maximum inflation is 50psi. The pressure rating on the tire is the highest pressure the tire is rated for. Not what pressure the tire should be ran at given the vehicle characteristics. ;)
RjSteed
Wesley Chapel, Fl
Point noted.... Has me wondering about my Tahoe now... Running 31" tires at max pressure and lot of vibration when going down dirt roads... Gonna have to let some out and see how it does.... Thanks
3dAngus
101
Perry, Ga.
The military used to run higher pressure for highway years ago.
They found there were issues at the higher pressure with the sidewalls, dirt, etc, and the tires would develop leaks that would require removal and reseating. It was manpower intensive and a waste of funds and time.
You will find mountains of good tires piled up after removal as a result. Many units find it appropriate to change the tire out when removing, and eliminate any doubt. They also ran out of air and drove on them, causing failures of another nature. Look for black rubber marked rings around the sidewalls for running on flats.
The 17 psi is more for off road, and yes, they will definitely bounce at 14-17psi loaded, and are supposed to.
I do not run 17 at highway speeds or anything above 30mph. It will drive you nuts. I have purchased a dozen or so M1101/1102s and they are almost always down at the 14-17psi area upon recovery operation, so the first thing I do is run the pressure up to 30psi. No more problems with bounce, and no leaks yet!
I would never run HMMWV tires up above 35 for any reason.
86m1028
17
Murphy TEXAS
There is a placard on the door that tells you what pressure is best for your vehicle.
Thats for the crappy factory tires they put on it !
Exactly why I remove that sticker & write in sharpie
"read the f***ing tire"
I run load range E tires on wife's yukon.
When it's taken in for service they drop the air pressure to 35psi
tires look flat when they drive it out.
86m1028
17
Murphy TEXAS
Lower pressure will cause MORE bounce ( more sidewall flex)
Flat tires WILL bounce !
Dont believe me put a flat tire on a trailer & pull it 70mph, see what happens.
Like someone else already posted about these m1102's 30-35 psi works pretty good.
emr
25
landing , new jersey
LOL :) An over inflated tire bounces more ") max tire pressure is stated on tire, and for a max load. factory settings are the best for most uses. Tire professionals at tire stores will never understand what those of us who run different tire pressures want and need . Sometimes I forget but usually give a note with the tire pressures I run,I also old school rotate, they don't understand that today, so I just give a note :) its not up to them to figure out the needs we have. they just follow the store rules :) Max pressure is also the least amount of traction :)
