Broke axle
50BMG
Caliente, CA
Broke an axel ,had to drive it home in front drive about 3 miles.my question is how do I get the iner part out?I have an ARB air locker on that diff.Any help would be appreciated, thank you.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Broke an axel .my question is how do I get the iner part out?I have an ARB air locker on that diff.Any help would be appreciated, thank you.
Middle or rear axle I guess? You can try to take the axle from the opposite side out and run conduit all the way through, so if your lucky you might be able to pull the stub out, but in reality, you'll probably have to pull the pumpkin.
rosco
27
Delta Junction, Alaska
Depends where its broken & if there is anything that you can get a hold on that is sticking out from the splines. Different truck but I once got a stub of broken axle out by using a piece of ABS plastic pipe, slightly smaller size then axle, making a longitudinal spit in the end & taking my jack knife and putting a bevel on the inside so it would get started sliding onto/over the broken stub. The split providing enough spring in the tube to grip the broken stub.If its too short, still use ABS, but large enough to easily slip over the broken stub & slide this tube flush against the pumpkin from the broken side. Reach through from the other side with conduit & push stub into the ABS tube to catch the pieces. (I might have had a 15 to 20 angle on the end too)
Good Luck
topo
219
farmington NM
In the past I have used a wire with a loop on the end that will tighten when pulled . Put the loop over the axle hold it in with long screwdriver or a rod and pull .
KsM715
142
St George Ks
I can't help you with the stuck parts however, I am curious, does this truck still have both rear axles? If so do both have air lockers that are tied together? Or is the truck bobbed? Just wondering why you had to drive out in front wheel drive? With the air locker couldn't you just engage the locker and keep driving the truck like it had an open diff? Wouldn't the locker drive the one good axle?
50BMG
Caliente, CA
I would like to thank you all for the great ideas,I will start on this as soon as it gets warm outside.My deuce is bobed,the axel broke trying to pull a ATT pole truck out of a ditch.I didn't want to engage the locker thinking it may do more damage to the axel.
50BMG
Caliente, CA
No I didn't get the pole truck out,he was buried up to his tool box on the right.But I also can't get the broke piece out.It broke off about 6 inches from the hub.I took the right axel out,put a 1 inch bar through and hit it with a sledge,did not budge,any suggestions.
50BMG
Caliente, CA
I think you're right FREDO,but I'm still gonna have to get the axel out in order to get the gears out.I have a spare diff,but I need that ARB locker out.I can't understand what's holding that stub in.
pigpen60
127
foley/missouri
My answer for a rear is, wack it, wack it good. Hook a wire loop on it and give it a tug. If you cant pull the opposite side and drive through your going to have wack it, pry on it to get it loose from the spider/side gears. Pulling the punkin is pointless since you have such a long piece in there. Like someone said earlier its probably twisted in the splines. Good luck! Take pictures! And I could be wrong!
50BMG
Caliente, CA
I was afraid you guy's wouldn't have good news for me.I really appreciate all your help and thank you.I don't know how to post pictures, but I will post on end result.THANK YOU ALL
50BMG
Caliente, CA
Well I got it out,there was no damage to the splines,I have no idea what was holding it.I took my tractor, a small 28 hp MF and armed it with the Gannon onto a 1 inch steel rod 4 times,it finally came out, slid the ďuece sideways a foot.Thank you all.I think PIGPEN 60 was rite,beat the **** out of it!
Armed is not what I wrote,it's supposed to be ramed.
