- 406
- 884
- 93
- Daytona, FL
that's on tomorrow's schedule....Take it apart slowly (incase of springs) and see if any O rings are in there..... get back with us on what you find.... appreciate it in advance
Ugh..$200 and $185 (used) from “that” outfit In MissouriYou have to have it for the air bags.
It's available
PP975900
Commercial ones can be 80 to $200 depending on brand. You get what you pay for. You aren't driving a 1990s Ford ranger. It is a truck built for the military and only them with no civilian equal so parts aren't that common or they will be a little more.Ugh..$200 and $185 (used) from “that” outfit In Missouri
There is one on the auction site with make an offer.i would imagine the principles are essentially the same…
and that's exactly my Labor day Sunday task..if it cannot be rebuilt...I'll give Bryce a call..he has done me real good on used parts...There is one on the auction site with make an offer.
However, the video seems to show that it could be easily rebuilt with a few O-rings...seems to be the cheaper way!
Good luck!
SWEEET..... let us know what specs you find on the O-ringsit's very close to the video I posted..not a big deal at all....View attachment 844314
harbor freight blue box...the largest o ring which is sandwiched between the 2 'halves' was fine .SWEEET..... let us know what specs you find on the O-rings
interesting.... the blue box is Metric. Was that just the box you had? Or did you have both metric and sae... but found a metric was closest match?harbor freight blue box...the largest o ring which is sandwiched between the 2 'halves' was fine .
had both red and the blue box...interesting.... the blue box is Metric. Was that just the box you had? Or did you have both metric and sae... but found a metric was closest match?
might be all metric. Apparently 3/6th allen is 5mm metric. curious if the threads are metric.had both red and the blue box...
11mm nuts and 3/16 allen wrench...go figure
.if anyone cares... for future reference
-Harberfreight vs others
-Oring and chemical compatibility
O-Ring Chemical Compatibility Chart Rubber Resistance Guide
Marco Rubber offers an extensive o-ring chemical compatibility chart to compare how different chemicals and o-ring materials perform togetherwww.marcorubber.com
-How to measure Orings
