Can anyone give a positive id on these rotors / stators
sandmanxx
San Antonio/Tx
Hope I am not breaking any rules on posting ebay link. You did!
Can anyone tell me exactly which MEP ?? these rotor / stator assembly go to??
SCSG-G4
PSVB 3003
3,320
Lexington, South Carolina
From the description, they go to an MEP-002A. I could be wrong, as I've never actually seen one. Check to see if he has an NSN. If so, do a Google search on the number and you will find your answer yourself!
sandmanxx
San Antonio/Tx
Kind of what I thought. No I didn't have a NSN but you thought what I kind of thought lol ! Close enough.
It was a "nubbie" to these generators mistake when I clicked buy one a while back. Can't blame anyone.. Didn't have it shipped as it really serves me no
purpose.
sandmanxx
San Antonio/Tx
well they aren't like my ONAN MEP803A windings .. [thumbzup]
But if they are for a MEP-802A i may just have it sent. Have to see if has a full NSN number..
One reason for asking here is someone has a correct answer just by looking at them ..
Chainbreaker
1,882
Oregon
Doesn't seem to match the MEP-002a Rotor Ass'y PN's, if it were it would match one of these part numbers:
6115-01-055-0389 ROTOR ASSEMBLY, EA 1 1 GENERATOR 72-5210 30554 201-1754 44940
Chainbreaker
1,882
Oregon
His listing says its a 60 Hz and one of the eBay pictures displaying the white tag references a pn: (201-3466) which is under the MEP -802a 60 Hz rotor assy:
Using: TM 9-6115-641-24P
Figure 24. Generator Assembly, 60Hz
Item 23 XDFFF XB 44940 201-3466 ...ROTOR CORE EXCITER 1 UOC: EMH
On the other hand, using the eBay picture displaying the pink tag, that tag matches a 400 Mhz rotor assembly for a Mep-812a:
Figure 25. Generator Assembly, 400 Hz
Item 21 PBFFF PBOOO 44940 201-3448-01 ..ROTOR GENERATOR 1 UOC: ENY
sandmanxx
San Antonio/Tx
See - thank you rusty.. I was "kind of" directed to those by someone.. Not anyone here, nor the seller..
Side note: it's kind of difficult doing layered research via a cell phone screen and questionable cell tower feed!
Dan Davey
Chino Hills Ca 91709
I had a questions that's related to this string I was hoping someone may know. I have a 2007 Fermount MEP 802a and I have a bad stator generator. The TM says the part # for item # 11 is 220-4265 with a FSCM # 44940 in front. I found on a new OEM Cummins Stator Assssy - WD G 220-4265 on ebay but I dont recal seeing the WD G letters in front of the part number. Does any body know what the WD G is for? I'm trying not to buy the wrong part.
SCSG-G4
PSVB 3003
3,320
Probably a subcontractor that deals with electrical parts, have you looked up the FSCM or CAGE Code?
Light in the Dark
5,663
MA
Are you looking at the stator from OSMI parts? If you look at all the photos, one has a shot of the sticker on the box (Cummins sticker). It shows the correct part number you are looking for.
