Can I have a hoist and winch?
Mitymac
Red Lake Falls, MN.
I would like to put a grain box on a couple deuce's. Can I splice a hoist pump in the winch drive shaft to run the hoist and winch? Or if I can't where would a person get drive and pump to mount on trans for hoist.
Thanks in advance!!
1,120
Use a transfer case PTO.
DO a search for "transfer AND PTO". You will find much info.
Transfer PTO's are how the factory did hydraulic pumps for dumps and such.
1,814
2 choices here. There exists an accessory drive for the PTO that would have a second output to the rear. It only goes one direction but that is just fine for running hydraulics. The other option is a transfer case PTO. This bolts to the back upper section of the transfer cans and provides full power in both directions to run whatever you need.
