Center axle seals leaking.
rtk
418
Lockport N.Y.
McMaster-Carr is supposed to have seals you can use , there are a few threads that talk about the QUAD seals . The problem is if you need the inner wheel bearing , very hard to find and VERY pricey . I am In the procress of changing my A3 over to A2 bearings and seals . Eric's has the bearings if you need them . Bob k:driver:
camp9
9
Yooperland, Mi
Don, I got some o rings from mcmaster-carr I have the same problem as do a lot of guys with A3's I'll look up the #'s and post them later. I don't have time to find it but I got the #'s from a thread on here that someone started and it had some great info for replacing the orings
