Skinny
- 486
- 83
- Portsmouth, NH
I am running 37" Goodyears on my M1031 with what I believe are late 70's Ford Campers Special rims or from a late 80's F350. They are 16.5x9.75 rims that actually fit quite well with the width and backspacing.
I just purchased H1 Centramatic balancers and they clear the axles/brakes fine. I have this inner lip on the rim which is interfering with the centramatic installation. Now my spare tire rim which appears identical to what is on the truck right now does not have this lip or interference issue. I do not want to purchase new rims or use spacers if possible. It would require 0.75" space to clear but I think the minimum size of spacer that you can buy with new studs is 1.5" width.
I'm no engineer but I did stay at a Holiday Inn Express, I'm thinking I could plasma cut that small portion out without compromising integrity of the rim. I think that is safter than adding 3" of track width to a set of heavy offset wide rims.
Thoughts???
Thoughts???
