Chevrolet 1982 K30 Diesel Dually 6.2l v8 3 Speed automatic -Project-
Isajel
Minneosta
I am currently fixing up my dad's old Chevy 1982 K30 Dually, and I was thinking about upgrading the engine to a modern one but I still need to get a new transmission. So I was wondering if anyone knew a good engine and transmission that would be able to fit in the truck, At the moment I believe it has a GM/Detroit 6.2l v8 Diesel engine, and for the transmission it is a 3 Speed TH400 Transmission, and if it is a modern engine I will have to find some knew circuit board and wiring kit.
dependable
191
Tisbury, Massachusetts
Modern engine = modern problems. With a 6.2 and TH 400 is there are no micro chips, circuit boards (not critical to running anyway) or fancy wiring to fail.
Just my two cents.
15,030
Welcome to the Outfit!
Post us a few pictures...
That way everybody can see what you are up to :)
15,030
I will soon I don't have my pictures on me so I will have to take some, but it is not in the best state at the moment.
Don't worry about how bad it might look now. We all wear special green glasses that makes anything military look better :cool: . In all seriousness though - having pictures of "where you started" and where you are now (a few months later) will be cool to have.
When I got my first truck, I thought it was in fairly good shape. Then as time marched on, I fixed a few things and shot a little "rattle-can paint and primer here and there. Then I needed to fix and paint some more. Truck still needs a full fledged paint job - but WHAT A DIFFERENCE - comparing when I started to now.
Bet yours will be me the same over time.
And, the pictures help keep you motivated when it feels like you haven't accomplished as much as you thought you would.
Isajel
Minneosta
Bet yours will me the same over time.
Ok, I'll send some pictures when I get a chance.
Isajel
Minneosta
I'm currently changing the fuel pump but I ran into a problem. I will need a new fuel line that runs from the filter to the pickup pump- the flarenut is to beat up so I will need to cut the line off. Does anyone know where I could get a replacement?
15,030
Basically the line itself is a steel "brake line". Not sure what the real name for that piece of steel line is, but at a parts house it will be called that. There could be a couple of ideas on fixing the chewed up flarenut. You could cut it off and buy the shortest piece of "brake line" (cheapest) and cut one end off it to replace the bad part. The flare is SPECIAL though. It is called a double flare (sometimes called an inverted flare) and it requires a special tool that flares the line twice.
The tool is available at places like Home Depot, Lowes, NAPA, Northern Tool and a bunch of others. YouTube has bunches of How To videos on properly creating the double flare.
The other choice would be forget the tool and remove the line you have and create the bends and replace your line with the bad end on it...
Isajel
Minneosta
I will be working on the body panels after the fuel pump, I ordered a replacement piece that should work for the flarenut fuel line. I was wondering if I should just bent the metal sheets back together or go for new body panels?
15,030
Glad to hear that you found a good fix for the fuel line!
I honestly can't claim any real skill in body work. I have seen several threads on repairing that sheetmetal though. A search for "rocker panels" shows several folks discussing how to make those repairs. Most of my truck body fixes require a wire brush on a grinder...
Isajel
Minneosta
Ok, thank you for letting me know i'll check it out when I have a chance.
Isajel
Minneosta
A little update so far; I have fixed most of the body panels already. Also have tried online orders twice and they did not fit for the fuel line, so I will be trying to go to fleet farm. I will also be putting the carpet and insulation tomorrow.
Isajel
Minneosta
Sorry for late update, I have got the correct fuel line but had to retry because I kinked my first one. Because I had a cheap tool that did not work. And I have not been able to paint because of the weather where I live so the carpet is not in yet.
15,030
Sorey for late update, I have got the correct fuel line but had to retry because I kinded my first one. Because I had a cheap tool that did not work. And I have not been able to paint because of the weather where I live so the carpet is not in yet.
Some progress is always better than none. Right? :)
At my place, all vehicle repairs and painting are tightly tied to the weather!
Isajel
Minneosta
Update:
The paint that I did looked very ugly and it had way to much orange peel on it so I'm redoing the body and going automotive path for a lot more but for a better product.
Isajel
Minneosta
Well there is a issue that I have to fix, the main gasket on the engine is leaking. I will need to take out the engine and transmission to do that. So its going to be a very painful process but hey I get the experience and maybe I might clean the engine up and paint the block. Does anyone have any tips or anything I should know before attempting?
