Clutches, Pressure Plates, Confusion
SierraHotel
Haymarket, Virginia
In perusing some of the different suppliers online, they do not all seem to agree with what each part number looks like. I looks as if RNJ Murray and Saturn buy from the same place and that Old Iron and American Military buy from the same place. However, that is where the two diverge…
Can I replace a 4 arm pressure plate with a 3 arm and can I replace a 5 tab clutch with a solid disk?
What freakin' disk and pressure plate should I get?!!
Does it Matter?
rdixiemiller
Olive Branch Mississipi
You should be able to use either the 4 arm pressure plate/5 puck disk or the 3 arm pressure plate/6 puck disk interchangeably. Which is better? They are probably equal. I would imagine the 6 puck clutch assy. would probably be a bit smoother than the 5 puck setup. The 5 puck clutch uses metallic friction material, the 6 puck looks like the fiber type. The disks should be interchangeable between the pressure plate types, the dimensions SHOULD be the same.
WillWagner
2,610
Monrovia, Ca.
There was a thread a few days ago, they had a 3 finger and put a 4 finger in and they were having problems getting it adjusted. Someone posted that the newer TMs didn't have the procedure to adj. the clutch, but the gasser TM did. What came of that?? I too am confused :?
acetomatoco
I would replace with identical to what was taken out...too many variables otherwise...who knows what soldier 1 and soldier 2 did over the years.. ACE
SierraHotel
Haymarket, Virginia
Re: RE: Clutches, Pressure Plates, Confusion
rdixiemiller said:
You should be able to use either the 4 arm pressure plate/5 puck disk or the 3 arm pressure plate/6 puck disk interchangeably. The disks should be interchangeable between the pressure plate types, the dimensions SHOULD be the same.
I thought the 3 arm/6 puck combo was for a 5 ton. Is that correct?
I agree with ACE and will likely do the 4 arm/5 puck combo, but am still confused about the clutch disk differences between Old Iron/American Military (White Star) and Murray/Saturn for the same part number...
