- 10,350
- 75
- 48
- Meadows of Dan, Virginia
I checked out Desert Rat's dual fuel tank project and as you know fuel milage is directly proportional to the weight of the vehicle.
Removing the spare would be an "improvement" and okay if you are running duals. Adding 300 lb of fuel would not improve the mpg's.
My deuce weighs 16,250 empty with me in the driver's seat and about 20 gallons of fuel. The best mpg on the highway empty for my deuce is about 9.5.
With cargo, 20,000 -24,000 lb my best mpg has been about 8.5.
I can see a stripped down (=w/o cargo cover) M35A2 getting 10 mpg if running on 11.00-20 tires.
Looking forward to seeing DR's results!
There are plenty of places along the interstates where you can weigh your vehicle. There may be a small charge for it, but check at the truck stops.
Adding an extra fuel tank looks like an interesting project, but not for everybody. IMHO I would recommend that any deuce driver on the highway stops every 250 miles or so just for an equipment check if for no other reason, shifting of cargo, tire pressures, bearing temps, lights, windsheld wipers etc.
Since I stop at weigh stations this is often a good time do the "equipment check".
My mpg data includes stopping for fuel every 250 miles, driving through weigh stations and warm-up and cool down times (about 30 minutes total).
I measure my fuel with a dip stick in the tank.
My golden rule for driving the deuce is "take your time and plan ahead".
If you post data about mpg's, include vehicle weight and tire sizes.
Regards,
Regards,
