FreightTrain
Banned
- 2,730
- 13
- 0
- Gadsden,Al
Anyone got a Compression tester I can borrow or know where I can buy one for a Multifuel engine?Seen several threads but none give a "Yes,this is the one you need" answer.
Very informative and I think useful...thanks for the tipWillWagner said:Don't waste the $. If the cylinder has low compression, there will be white smoke all the time and lots of blow-by...that can ONLY be measured with a manometer and compared to a reading from the MFG of the engine...if ANYONE has the specs and measurement procedures for the multi, POST UP! The failed cylinder can picked out by cracking the line going to the injector and watching the smoke to see which cylinder makes it go away. When the failed cylinder is located, the smoke goes away
Low compression may not kill a cylinder.Don't waste the $. If the cylinder has low compression, there will be white smoke all the time and lots of blow-by...that can ONLY be measured with a manometer and compared to a reading from the MFG of the engine ...
