Couple of oil questions (mechanical)
ldmack3
1,739
N. Central Idaho
How do you torque the 3 self-locking bolts that hold the oil pump in place? 2 of the 3 have no room for a socket and torque wrench and barely enough for wrench.
After all is done on piston replacement, I want to pump some oil throughout the engine prior to starting. What is the best port to use? I've read just pull a plug from and oil passageway but don't know which is oil and which is coolant. Does cranking for 15 - 30 seconds without starting do any good without harm?
jake20
845
Illinois
If you're talking about the 12 point ones on the outside, I just did a pump swap recently as well. The top was easy obviously, the sides took a little bit of tedious effort.
I did my best to wire wheel the studs on the timing cover before attempting to put the pump back on. That made it a LOT easier to hand thread the nuts almost completely down once the pump was on. After that, I basically sat and turned my 15MM wrench 1 notch at a time, chances are you won't even be able to fully slot it onto the nut either. It took a while but I got it torqued down to what I felt was right.
They also make some funky shaped wrenches just for those, but I got by without them. This is what they look like, can probably find them elsewhere for cheaper: https://www.amazon.com/OTC-6087-Injection-Pump-Wrench/dp/B000Q6U28S
EDIT: Read Next Response
jake20
845
Illinois
Wait - Ignore me, I read "oil pump" as "fuel pump" in your post 😂
Dealing with too many pumps as of late... anyway, I'll leave my previous response up for anyone else that might have to deal with the injection pump.
