crankcase vent tube?
Monster Man
should this thing be going over the side of the engine and pointing right at the fenderwell/ground? At first I thought my turbo was leaking cause it ran right next to it, but I got to looking and it appears to be the vent tube leaking. Is that right?
thanks
1,807
It should be pointing towards the ground. Take a pic of it and post it. You might have a non turbo vent tube and if so it kinda points to the fender when installed with the turbo.
fujinama
They say that a lot of the oil consuption goes right through that tube. Don't worry.
I saw a picture of a trap that someone put on that tube to catch the oil and return it to the sump, so there is a fix. The military supplied drip pans for the crews to put under it.
