- 5,815
- 8,081
- 113
- Papalote, TX
I am curious about the CTIS system for the HMMWV, I understand very few were installed from the factory so there will not be allot of folks that can answer these questions.
1, what is the max pressure the factory system will allow?
2, are there normally any issue with the seals in the hubs leaking?
I have a set of hubs that I plan on going completely through before installing so they will have all new seals, since there are no HMMWV systems out there to be had I am ether going to adapt a different vehicle system or just home brew my own system.
I did see a video on a rather high end system that had remote controlled valves which had two advantages, 1, they would "dump" really fast and 2, they would only have air pressure on the seals when making a change, otherwise the valves on the wheels would be closed and the system blown down, pretty dang cool but obviously way out of my budget.
