- 1,918
- 105
- 63
- Colchester, VT
I've got another set of these pedals to sell. This is a hydraulic clutch pedal setup for square body Chevrolets, great for an NV4500 or SM465 swap. This is a vacuum boost set, but all you need to do to convert it to fit hydroboost brakes is swap in your cucv brake pedal and cut of the excess pad. Then cut off two of the mounting studs (your hydroboost has them already). Works great.
As you can see in the pics one of the spacers is missing on the end of a support rod, that's an easy fix then add bolts to hold the master cylinder.
$300 plus shipping cost from VT.
