Detroit 8v92 fuel shutoff question
Rkrug
Hays,KS
Looking at a truck that has an 8v92 and a 13 speed, says that it runs good but has an electrical issue and then it dies. So here are my questions being a 1979, this should be a mechanical engine (no DDEC?), meaning that the only electrical issue that would stop it from running would be concerning the fuel solenoid? If so to get the truck home to fix the problem could I just tie the shutdown lever in the run position to get it home?
Thanks for your help!
Rkrug
Hays,KS
Ok, I think I have it figured out, talked with some one and they said it probably has an air actuated shut off and the valve that controlls it is bad, so that once the truck builds air pressure it kills it, so I just need to cap that line.
