Deuce batteries or starter
779
20
Springfield AR
OK guys when it rains it pours sometimes.I got everything back together went to start the truck I got a clunk. I charged the batteries took them to the parts store they tested them and said they were good.I cleaned the terminals and grounds still clunk.I am not sure if it's stuck or the solenoid is bad.Or something else it was fine when I put in the garage so I could work on it a few months back.The batteries are the 6TLs.
1,168
Well, what have you done lately?
What did you get back together?
779
20
Springfield AR
I ve got videos uploading for my transmission rebuild uploading as we speak I'll get the links up as they upload to those threads.I have also done all the brakes axles seals new boots tubbed my fenders flipped rear hubs.I ll have those videos up soon.
1,168
Does your motor rotate by hand?
1,168
Does your clutch feel right?
Roaddog58
Dorset Ohio
Try taking jumper cable from positive to starter, with truck in neutral and wheel chocks in place. or take a hammer and tap side of starter?
JDToumanian
14
Phelan, CA
Since the batteries are good, it could be dirty or pitted contacts in the solenoid. I've had it happen, I just pushed the start button a bunch of times and it suddenly made contact and started. If the clunk is the pinion gear engaging the flywheel but the starter is unable to crank the engine, I'd definitely try barring it over - with the stop cable pulled out so the engine doesn't start from you turning it with a wrench.
Jon
779
20
Springfield AR
OK took the starter loose thought maybe it was hung up it did spin but not engage when jumped and when I took it loose then retighten after wiggling no go.So it clicks but doesn't engage starter but starter does spin when jumped.
texas30cal
87
Brenham Tx.
Take the starter and solenoid to your local alternator/starter repair shop, they will prob test for free and are usually pretty reasonable on repairs.
JDToumanian
14
Phelan, CA
I agree about a repair shop, but I've opened up solenoids and refinished the contacts with files and fine sandpaper... That's probably all that's gone bad in there, especially since you were hearing it move but it wasn't turning the motor on.
