Deuce Door Latch Spring
AZDeuce
Tonopah, AZ
Good Morning Ladies and Gentlemen:
My driver's side door latch failed, I read the SS article regarding repairing a broken door latch, and decided to take mine apart and beat it back into submission.
But alas worn parts was not my issue, a broken spring was....you know that "curly Q" one.
Does anyone sell those, is there an alternative, or is there a way to make a replacement?
Or does anyone have a good used drivers side latch assembly with the spring for sale?
Thanks in advance - AZ Deuce
JCKnife
46
Kentucky
Is this attached to the cab? I might have one from my parts truck. If it's part of the door I want to keep those with my doors.
Edit: you must be talking about a part from the door. I removed the door catches from my cab and saw no kind of spring. Sorry!
Deuce007
North Dakota
My truck has a problem like this too. The door won't latch from the outside you have to manually turn the handle from the inside.
