Jakob
- 5
- 18
- Louisville, KY
If it is something aftermarket just similar cost, but will last much longer and not as prone to failure, I would be in the market for it.
Indeed. When the flasher is not working and I turn the stalk to "left" and remove the green cap from the unit on the steering column, I can see the lamp glimming. It does not glim in any other stalk position. After a while of glimming, the flasher will spontaneously come on and (usually) work fine from then on. It can take anywhere from a couple to ten or fifteen minutes of "glimming" for the flasher to finally come on.interesting...I am having the same issues, I noticed that if I leave the flasher on for a while, the lights will be steady...then start to blink....after that, they seem to work fine...but is like they need to warm up or something before the lights will blink...
Hmm...interesting, the case of the flasher unit is normally isolated already, that's why you need the "C" wire connected to ground.Didn't find anything on what the voltage should be going into the unit but I did find out that it is wired correctly. So here is my fancy hi-tech fix.. mounted it to a piece of wood..Now my flashers flash..
