Dieselsmoke
- 2
- 0
- CA/NV
Got some nice weather today and some free time so was finally able to do some more work on the shop van today. Things went well, got ALL of the lighting working. Replaced a few bulbs that were blown, had to install a new 3 lever light switch as it was bad. After replacing the light switch the two headlights still did not work. They were brand new bulbs that had never even been plugged in Still can not get the light in the turn signal lever to work but will mess with that another time. One headlight bulb had the high beam burned out, so found a takeout bulb which just so happened to have the low beam burned out While replacing the headlights I found that 4 of the rubber spacers that hold the light panel in are busted so if anybody has any I'd like to purchase 1/2 dozen or so.
Did some work in the shop van itself and a couple of the lenses for the 110volt lighting are cracked so would like to find a few of those, the blue ones if possible. Also need the arms for the doors that keep them from swinging too far, both mine are bent.
I'm also in need of the 2 rear shackles, since for some reason they are a different size than anything else.
Was a good productive day, nothing better than getting some work done on the projects!!
On edit-also looking for the ventilation blower at the driver side rear of the 109 body, mine's in bad shape.
