- 143
- 16
- 18
- knoxville tn
Doing front axle PM on a M936A1, and found the following "little" bit of oil on the back of the brake pad, seems to be coming from the brake cylinder. no fluid on the pads face or any where in the hub area, only this little bit on the back.
I did not think they contained any fluid (or am I wrong here?)? so is this just years of minor leakage from grease/lub breaking down in the brake cylinder or do i have a bigger issue? (couldn't find any past posts on the cylinders for non hydraulic 5 ton brakes)
1st pic shows bottom of cylinder and wetting on spring and pad back
2nd pic is the spider with pads off - you can see the "wet" stain, no real fluid. (the wet oil stain on the diaphragm tube riser is from penetrating oil I added)
3rd pic is the bottom inside of the pad
so just clean it up and reassembly? need new parts? if so a review of the parts places did not turn up much?
just found this part at Oshkosh (brake actuator piston), does it contain fluid? could not find in TM any info other than parts , but this is the part that "looks" like the source of wetting .
